Hey guys, ive been working on this for a little while now (you can see my sketches are all MK6 ) and I think I have finished or have come very close to finishing the design. I will 3d print everything tomorrow as a test fit, if all goes well I will mill two out of alu 7075 (one for me and one for @psychotiller) once testing is done maybe I’ll do something like a group buy depending on interest.
Well… I attached everything BUT, the motor mount holes were off by a few mm, I realized the clamp won’t work in aluminum so I’ve decided to completely redesign the entire thing…
Cost would be somewhere in the ballpark of $30-$45 per mount including hardware (and maybe a belt)
Just a survey to see if there would even be any interest in something like this, obviously I will build one and post some videos and pics and send one to @psychotiller so you all know I’m not lying
I would be selling through an adult on here since kids like me have a bad rep thanks to @Alextech…
Edit: I just accidentally voted on my own poll
Once I get one working prototype and some money to buy caliber trucks or whatever truck you would want it for I’ll definitely work on making clamps for different trucks
UPDATE: I will be getting my alu tomorrow but won’t be able to mill until Monday, I will definitely post some pics once it is mounted, GET HYPPPPPPPPPEEEE!!!
The problem you’ll have is that when you clamp down on the clamp itself, you’re moving where those three screw holes are by sometimes a significant amount. Then, when you try to bolt/screw the actual mount to it, the holes won’t line up.
What you need is to make those holes (in the mount plate) a little oversized or oval, to compensate for the movement whilst being clamped.
Also, and I’ve said this so many times, milling ‘teeth’ to the inside of the clamp will help it stay in place when clamped to a round truck.
I’ve thought about all those things, I do like the extended holes idea though. As for the teeth, I think your referring to the things on the Hobbyking motor mounts, the two knurled stock screws should be enough. Also the clamp shouldn’t be tight enough to move the holes out of alignment
