Looking to build my first electric skateboard. I live in San Francisco and I ride my motorcycle to and from work around 5 miles each day. I commute from Lombard street down to around the AT&T Park area. Considering that I don’t need to ride my motorcycle, I think it’s time for an electric skateboard to do my commute on.
This would be my first build and after researching, I think it’s time to ask for a bit of help on where to start. I might know how to solder and the stuff but figuring out exact electrical specifics it can get daunting to me.
I’d like to budget around $1000 for everything but always willing to spend more if needed (Definitely not more than 1400). For a deck, I really like the look of the raptor 2 deck where its a cruiser style deck with a tail which is what I would like. With my commute, I only need to get over Russian Hill but after that, not much terrain and I could even bypass this by going through the San Fransico Bay trail. Range, I only need enough to get to and from work which is 10 miles in total (5 there and 5 back). I wouldn’t ride anything faster than 20-25mph. I’m about 6’3 and 250lbs so i’m for sure needing a no flex board and a dual motor setup for both me and the terrain around here. The weight of the board all I have to go is up one floor and then just leave it there for the day so carrying it around isn’t a problem for me.
I have access to tools with everything from a full wood/metal shop along with 3D printers and a CNC machine through my university. I’m also good with programs like CAD & Rhino should the situation come up.
I’ve read through quite a bit of guides both on here and on other websites and i’ve started to gather information.
For the items, i’m not set on where i’m buying the items but more just want to finalize what exactly I want to get so if anyone has any recommendations on vendors they’ve had a good experience with definitely drop the names.
Battery Pack- either a 10s or 12s if needed
ESC- TorqueBoards OptoESC
Motors- dual setup definitely. Thinking a 190kv if I go with a 10s battery or a 170kv with a 12s battery.
Wheels- 90mm
Deck- 38" (thinking maybe a jet deck)
Other things such as pulleys and how to gear them are things i’m still currently researching so I’m just wanting to make sure i’m on the right track.
