Hello guys! I got a new FocBox… my first one. I tried to connect to pc, but id doesn’t show up on MAC oder WINDOWS. Do I have to do something special? My VESCs or Arduinos showing up normally…
Is there any trick? I connected it to my charger and the USB to pc (as I do it for my VESCs). the FB starts blinking red and then stay solid on blue (power).
I read in one of the threads that @CarlCollins suggested to clean up the micro USB ports on the focbox. Sometimes they covered and the connection is not good because of that.
I had one like that and it turned out to be the usb. Had a small piece of film stuck in there but I had to take it out of the casing to clean it. Make sure that support are good with that warranty wise. Sure they will be.
Running it on Mac. u don’t need any device manager. A lot fo VESCs worked fine so far.
I tried some different cables, different power supply, different pc. It just do nothing. it should also light up when just plug in the usb cable without power supply. Also doesn’t light up.
No combinations work. Whats next? Connect @carl.1 ?
I am really disappointed … I needed this part. Now I have to wait for another month…
Also the plug on some usb cables is too short and with the focbox case on cannot be inserted fully.
Try taking off the plastic case and make sure the plug is fully inserted.
@StefanMe
I think I am able to help you, Can you please do the following?
remove your FOCBOX plastic casing and connect the MicroUSB cable.
And check if your MAC recognize it.
After removing the plastic housing, the pc is recognizing the FOCBOX. But the PC detects it as UNKNOWN DEVICE (WIN). I installed the latest BLDC Tool from your website… is there any driver i need?
