Not much time for ESC coding I have done motor control and detection, but need to cover it up with PPM, configuration and etc things. Probably will return to it after new year (Hard to code as the whole toolchain is windows and eclipse based pretty nasty stuff to code in)
At the moment, working on much more needed thing at least for myself
^ @Hummie by reducing drag coefficient and frontal area, you can use larger diameter tires to get ever higher speeds (ie street luge will have much lower frontal area and drag coefficient vs standing rider)
If you look at the outside (look at it just like in my profile picture) at the inside ring (a small black circle) it should say japan if they are the Japanese bearings.
The biggest issue I still see for mass producing these is that every motors wires come out in a different place. So you have to wind the motor for a specific truck so the wires come out in a good place (between the truck and the board). I canāt understand why John sent you a motor with the phase wires pointing downwardā¦ The only fix is another motor made specifically for that truck.
Or u can sand where the motor contacts the hanger n take it down a bit and then it will spin more and u can adjust the wires that way. All of the motors would benefit from having the hanger aluminum cleaned of paint or adding a bit of thermal paste at the connection. I didnāt do it. It costs less then 20$ for the tools to take the motors off n on and you can do that. Iām tired.
Alright, I was just curious if it was as simple as loosening bolts and rotating. Iāll figure out something, not worth the effort of sending back anyways haha.
They canceled school in San Francisco due to the air being in the red zone from the fire above so no work. have 5 more sets boxed and going out. USA and Australia. And have the week off and have about 1/3 of them still to get out.
So in @Hummie s defense, I was able to flip the hanger to the correct orientation. Wouldnāt go together like that when I originally installed it, but with some gentle finessing with a large sledge hammer(kidding) it worked.
Wires stick out a little still, but this is easy to protect now.
