Hey, i’m currently making a loopkey for my board and i thought that i would share it with you guys to get some feedback.
The connectors are AS150 and will be encased in epoxy resin, the dimensions are 34(w)x28(h)mm (panelmount) and 27(w)x32(h)(16mm when connected), + wires coming out behind the panelmount.
What are your thoughts on the size of it? would this fit in your enclosure?
The connectors will be completely encased by epoxy resin so no replacing connectors, bad/good? failure rate on AS150 connectors?
Give me the good and bad you see with it, I want to make as good of a loopkey as possible.
Try taking a look at Offshore Electric’s 8mm antispark connector rated at 200A. It’s the bigger brother of a XT90S. However, it is quite bigger than a XT90.
They’re out of stock though until June. I’m picking up a bunch once they come in.
Looks hard to grab imo. biggest annoyance with loopkey rn is having to pull on the wire. Stress on the solder joints and such isn’t great. Also, The xt90s is just a bit too tough to plug in and pull out. from a friction standpoint that is. Though I suppose that’s partially an advantage since it is less liable to fall out unintentionally
Will take a look, but im worried about size, keeping it slim is a priority since the space inside enclosures. What would you say is an acceptable size inside enclosure? In my opinion 50mm is quite large
I don’t like to keep loopkeys in the enclosure. I usually route them so that they’re outside of the enclosure.
Once I get my hands on some of those connectors I’ll post the dimensions. I tried to order last week but they ran out.
EDIT : 86 that, they have some in stock when I checked this morning. If they still have some in a few days I’ll order a bunch and post the dimensions once I get them.
