Any left? And the Battery indicator function does it work properly if i use a maytech Vesc and 8s Battery?
sorry for the late reply… I have some left in stock. AFAIK the battery indication only works with 10S.
Hi Alan, is the 10k resistor really needed?
Vibrator confirmed
No,
I have been using it without the resistor for over half a year now (@ 10S, regular 3.6/4.2V18650 Cells)
Perfect! Thank you
I have this remote, during bench tests it works just fine, but when i ride it disconnects after i stop throttling? Any suggestions? I got it to replace my nano from torqueboards.
Pins maybe are rattling a little in the Jst? Could be soldered on to ensure that is not a problem.
Inspect the battery in the controller to ensure it’s ok
What’s your esc? Maybe it’s that which is resetting
Im using the unity, its not that, it only happens with the maytech remote and reciever.
Im going to look at the reciever and see if i can re posistion it or see if its being blocked
I had some disconnection. Issues when the receiver was touching the phas wires or was too close to them. You can also try the procedure from maytech to bind the remote.i Have to find it again in the net.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://shop.elektro-skateboard.de/media/pdf/b1/20/87/Manual_MTSKR1712_en.pdf&ved=2ahUKEwi69vTnld3iAhXHIVAKHTUiDOAQFjAAegQIAhAB&usg=AOvVaw0jlvTqbFVOoafvG2os5btQ Check the pairing paragraph. The remote worked for me out of the box but I once had to pair it because it worked but was acting weird on another vesc.
