@moderators anyway this discussion can be split from this thread… it’s not that relevant. It’s the end all debate upon whom has sovereignty over whom.
Edit: PS. @mmaner I’m with you bro, if we can’t recognize Taiwan then none of the former SU satellites deserve sovereignty either , or hell , everything should belong to Mongolia . But nonetheless the sovereignty (which that do cough cough) or non-sovereignty of Taiwan’s has nothing to do with VESC
Your right, I’m happy to delete my comments. I’ve done a pretty good job of letting these things go lately, but this is one I feel strongly about as I have family there.
Regrardless it’s nothing to do with the topic at hand so Ill delete if I need too.
It definitely feels super solid and heavy.
It’s drenched in this white silicone for the water proofing, so I can’t really get it out of the case yet.
After a few runs on it I’ll try to dig it out and see what it looks like without the case.
Also looks like there is plenty of space in the case to stick in an HM-10 module.
We’ll see how this goes.
I’ll set it up later tonight and first test run will be tomorrow
@oriol360 when you get a chance can you post pics of the setup with this FSvesc… Just want to see how folks are setting it up, especially with the Bluetooth in the enclosure.
They do not come with a bootloader… easily fixed with VESC Tool
Doesn’t actually work. All the setup goes through fine, I can run motor detection and see the controller effecting the duty cycle but no actually spinning on the motor… Really weird, never seen an issue like this before.
Out of the 5 I got, 2 have this issue, 1 seems to be working fine, the last 2 I still haven’t tested. (Got pretty busy and annoyed with the first two…)
I’ll be reaching out today too see what’s going on with these two so far. Will also try to make and post a video sometime of what’s going on… I don’t feel like I’m explaining it well.
@Deodand So far HM-10 does fit inside the case and works on the 10 ft away… I’ll walk away further next time
@Jc06505n Power switch is soldered on and covered with silicon.
Well my 2 are probably waiting for me at the post office so I should have them later. BUTTT I got band practice so I’m not going to be able to play with them until Thursday.
If you do get it working, or dont get it working can you post a quick clip of it in action. Would be great to see anything on this product from the hands of a DIY member.
Yes, they are friggin’ massive, the case feels solid in the hand and fits together really well. I will have a play with a receiver and BT module tomorrow and see what I can fit inside.
Same insides as @oriol360 with the white goo every where but hey, I will deal with that if they make a dual case.
Plugged a 4S lipo and the vesc tool and both have FW 3.37 installed, bootloader etc. One problem, I can’t update the FW’s using the VESC tool or Ackmaniac’s tool. Uploads all good, but shows the same FW when it re-boots.
That’s as far as I have gotten. I need to go to bed but I will solder some bullets on the then and see if I can get though the setup tomorrow afterwork.
