So while trolling along came up on thread about someone cutting some of the hanger to make a motor mount and wheel pulley fit… that would make you truck slim shady, IMO. Kinda got to thinking of a way to get away from the traditional bearings that occupies part of the axle by making a ball bearing around the hanger using…
iglide® J260-PF (filament for 3D printing, “igus.com” to view specs)
How is this better than using a bigger axle diameter and having it protrude from the hanger further? One truck on the market (that I’m aware of) currently has this.
Could you use a regular bearing around the hanger?
As @PXSS said, the bearing this size are expensive, but worth, since I started using bearing on the pulley I won’t go back, the drive train becomes stiffer since there is no moment being applied to the wheel bearings
I think the best approach is to have your hanger turned to fit a comercial bearing directly, this way you keep most of the strength
@Pedrodemio Nice work on the truck. Looks a lot like trampa titanium truck.
@b264 I guess this thread could have been a real long way to ask what kind of truck should i use.
So here’s the skinny on the bearing/pulley…
-Sounds good in theory but seem to have gotten feedback on ,Calliber particularly, trucks would have enough variance that this type could not be mass produced.
-Even if you printed to custom fit, the material, or any other printable plastics, as a bearing will not hold up to the RPM’s + load factor.
I spoke with Igus directly about it.
Which brings me to the next…
Igus boasts on the filament being 50x more wear resistant than any other printable plastic. This is do to that it is a dry lubricant.( Hard as F to print without buildTak)
Would this be a good candidate for a wheel pulley?
(+'s)
-maybe aid in belt life
-quiet operation (belt noise).
(-'s)
-possible slippage
I’ve got a spool of Igus. if there is interest in testing, could print a couple out and send out.
“Ain’t nothing but feets of snow here”
I used igus bushings on my 3D printer, I guess it’s a similar material. Within 6 months I had to change back to linear ball bearings due to wear and losing precision, and I don’t even use my printer a lot
In a bearing use the wear should be a lot higher
BUT go for it, that’s how inovation works, you keep going when everybody says that you are crazy
Such a bearing as shown in the first post is a very niche product and to expensive to market to others. Not to mention, cast longboats hangers are never square relative to the axle. It can be done.
I mean that’s basically what boosted board did with their V2 rear trucks and drive hubs. They used a big bearing lodged in the drive hub that rode on a coaxial part of the truck hanger. Pretty ingenious if you ask me.
Exactly, the boosterd does is that the wheel doesn’t have the inner bearing, it’s the pulley bearing that hold everything, it has advantages and disadvantages. In my case I would never trust my 3D printed pulley do the job of supporting my weight
