Ok thanks what would you suggest for a battery for the above setup, given I want to get up to 18-20mph and ideally 20mile range? If there are battery Builders on here that sell there services could you tag them please, cheers
I don’t think it’s a very good idea to use a 270kv motor with a 10s battery. You will be loosing out on potential torque, and you wouldn’t be able to go much faster.
Try to find a 200kv motor, and change your gear ration to 16/36
The speed calculator you used shows it. Read through the centre of the page.
Or if you’re using the black more complicated one it’s in the top right corner.
But here is the basic calculation eRPM = pole pairs * RPM, eRPM = 7 x 9720 = 68040
normally you can Charge 1c of your battery meaning if you got 3000mah 3Ah You can charge at 3Amps Its just so they can calculate your charge time for you.
Attempting my first build only part ordered so far is the focbox unity. I think I read somewhere…I should buy the battery first then build around the battery. Thoughts anyone?
