If these two items that I selected would end in something disastrous, please advise me with the correct information and I greatly appreciate your help, thank you.
The most concerning thing to me, is everything you didn’t ask. Skate batteries are not easy or straightforward to build safely and there is a lot of outdated information online. Making batteries for skateboards is extremely dangerous.
How do you plan to make the P-packs? would be my first question. Where is your instruction coming from? How old is it? Does it involve soldering cells? Is it limited to YouTube?
VESC 4.12 is really outdated, but would work at 10S
That no-name Amazon BMS I would not use
That MBoards BMS is just a rebranded Daly BMS. Ask what the balance current is. Also, it says Sold Out. Never plan a build around using unobtainium. Daly 10S BMS are available on AliExpress though.
If you’re not given a balance current, assume a BMS doesn’t balance, and DON’T GET IT.
I would stick to Daly if you plan to use a “dumb” BMS.
You should still ask them and have them tell you, even if you think you know. Many BMS look identical but have different layouts & settings. Plus, you want it written so if it doesn’t balance, then at that point it’s defective, because you asked, and didn’t assume.
