When I plug in my nano x receiver to my vesc it doesn’t get a red light at all. Any ideas?
Take a voltmeter and check the voltage between the middle(red) and the black wires that goes to the receiver.
I did and it says 5 volts
can you share a picture with the wires connected ? from vesc and from receiver?
Then you should at least see a flashing light. Probably something with the receiver. Been having issues with the nano-x receiver as well.
Did you try plugging it the opposite way? did you try plugging it to the 2nd channel?
Yep nothing
Then i’d say it’s the a faulty receiver. Do you have a different remote receiver laying around?
I have a different receiver
Did you get any lights or signs from the other receiver?
Yep 10 charc
Issue is with the receiver I guess, Can you please email at [email protected] with all the images and your order ID (if you have one?)
Sent email
