HELU PEEPS! sooo im trying to build a DIY Battery and a DIY eskate (obviously) and i have the following parts in mind. i have a bamboo long board (its pretty long) and is medium in flexibility. BUDGET LIMITED AF. so these were picked “carefully” to give “absolute performance”.
MOST ARE ALIEXPRESS SHYT BUT WITH FAST SHIPPING (like 2 weeks to canada)
motor:
this thing: (used for a charger? idk)
trucks:
remote: ( does this work with the vesc? )
VESC: (will get a coupon from seller too)
batteries: (good reviews…seems legit 3500mah)
charger: (no idea what cable is needed for bms to connect to this BS)
BMS: (with bluetooth so i can check on batteries and blah blah)
wheels: (4 of them)
wheel pulley: (does this fit the wheels above? it says 17mm like wtf man)
mount: (option A)
mount: (option B)
confusion 1) is with the amps and volts (noob level -99)… basically i want to use the BMS with bluetooth because it shows how much miles and battery status left on your phone (which is like A++) and i dont know if it can handle 40cells (how tf do you calculate). also the configuration of the battery… how many configurations are possible for my case (if any)?
confusion2) is with the on/off switch (link one from ebay i beg u). how do you also wire that switch to work with the parts listed above?
confusion3) is with the freaking motor mount. which one do i use (if any of the options above work)
confusion4) is with the wheel pulley. i found enertion pulleys that are 12mm but these suckers on ebay say they are 17mm? ebay ones are half the price of that of enertion so i was wondering if they fit a 83mm wheel.
confusion5) what how where do you get a cable for the charger above that connects to the BMS? any alternatives?
confusion6) is with the remote. does the one listed above work with the VESC? if it doesn’t, can you give a link to one that works (ebay preffered)?
so what i want from this build is high milage and medium to high ish speed (30-40km/h? no? ok)
ALL ANSWERS AND SUGGESTIONS ARE VERY GREATLY APPRECIATED!!!
