Hi everyone, I have decided to pull the trigger and get the parts for my longboard.
BATTERIES
For the batteries I am going for a 10s3p pack. Using Samsung 30q. I had originally decided to go for 12s3p but decided on a safer choice, as well as seeing the majority of people do 10s. What do you guys think???
VESC
I am going for the Hobbyking Vesc due to it being cheap. And having a 1 year warranty in case I mess up. Has anyone had any experiences with it??
MOTOR
I am going for a sensored 149kv motor from Hobbyking. Any experiences? Or shall I go for the sk3 equivalent.
WHEELS
I am going for the MBS all terrain wheels, they will be great for the rubbish pavements in the UK. Will they fit with these pulleys??
Is 15:36 gear ratio ok with the of motor I have got? I am about 70kg (150lbs)
I have got a 10s 60a bestech bms, it has an eswitch so elinates the need for an atispark key. I have got it from eskating.eu is this a high enough amperage for the battery pack.
The rest is fine, maybe the remote I would change just search āwinning remoteā here on the remote on the forum and youāll reviews of that
The rest is fine
The mount, the clamp looks like it was made with really low tolerances and that motor plate looks really thin. And probably uses 6061 alu if that - not 7075. Just look at the 1 star reviews lol, I wouldnt buy anything that was 2.9/5 stars
And for you pulleys, I canāt figure out if the motor pulley is aluminium or steel, not a huge issue but the description doesnt state anything about it.
The winning remote looks the same as the remote I have listed. In regards to the motor clamp, I am going to use it for the time being. I am doing this as part of a gcse project . If it turns out to be rubbish , I could always mill a new one or 3d print and then cast one. Thanks so much for the help.
what does exp mean? also everyone has got sk3 motors. these sk8 ones are sensored are they any good. I canāt seem to find much. also do you think ill be able to get over 20mph with a 15/36 pulley if i weigh 68kg??
http://calc.esk8.today/advanced/
Pretty reliable calculator.
You can buy motors from APS(AlienPowerSystems) he is from the UK, he has good prices and since you are not that far away, a good chance for some quality service.
There are other vendors
