Hi!
I recently decided to try building my own electric skateboard, and started picking some stuff out.
Im having some trouble picking out a VESC.
I want a VESC working with
6370 170 kv motor - max 80 Amps
10s2p 30C lipo battery 9000mah
I was wondering whether a 50A VESC would be fine, or if it would decrease my boards efficiency too much?
I was hoping if there was any experienced builders, that would help me picking one out.
Yes, like @Crisfell said you can use a Unity VESC in super single configuration. No other dual is going to work on a single motor except the Stormcore duals.
For other options, a regular FOCBOX VESC 1.3, 1.6, or 1.7 will all work great, as would a TB6 VESC or ZESC Warrior 6 or Raiden 7 VESCs or a Trampa ESC 6 Mk5 would work as well.
If budget is an issue and you’re not as concerned about performance, you can use a VESC 4,12 like the Torqueboards one that’s currently on sale for $39.99
Thanks for the help!
I think i will go with the TB6 VESC or maybe the VESC 4,12.
Regarding VESC 4.12. What kind of performance issues will i get?
Will i loose both speed and torque? or just torque?
Thanks in advance
