Another one I like (if you donāt have a rounded file) is to use a ball point pen, marker, etc slightly smaller than the hole and wrap sandpaper around it.
Poor manās file.
Poor manās file.
Dude a drill bit isnt the way to go you need a stepper bit. A standard bit would probably ruin the fiberglass since a previous hole is already drilled. @Bor.inc The step bit would be the quickest and easiest.
This step bit would be what you want. Nice high quality bit. I have used these with sheet metal and and have done a great job. Just go slow and it will be fine.
wow 200iq right here haha never thought of that, just like using a drill as a dremel
Hello I have a dual 6s lipo 8000mah 60c should I run it in series or in paralleI i run them on the focbox unity 6374 170kv 2800w sensorless
There is nothing wrong if I asked something in This group itās is called noob questions so I can ask what I want but sorry if I asked it in multiple forums
Will angled spacers fuck up a RKP truck set up? (+15 degrees)
Depends on your decks tip incline, what baseplate you have from surfrodz, and what youāre trying to accomplish.
series or parallel. what do you want?
I mean if I can connect everything in parallel I get more range right? but I do not know how much (a current) I can get with 6s2p for each engine
AS i said many many times
DO RESEARCH, learn about electronics a bit! you dont even know difference between series and parallel what it does with voltage and ampere etc. pls listen for once to me! holy shit
DO RESEARCH
read this please, its not a long read, nor is it terribly hard to understand
you need to learn the basics so if something happens, you have a chance of fixing it before anything more happens
I think you need to do some more RESEARCH use the search function. And please learn the basics of electrical circuitsā¦
I will do more research thanks for the link
for a beginner like you, a pack that has a S number of 10 would be recommended. Increasing the P number WILL give you more range, but you cant shrink one group and grow the other, youāre still ending up with the same amount of cells.
Do some more research, and remember that if youre going with a 10s battery, the highest kv belt motor you should go for is 190kv.
No more hints. get to learning
yes I know but I thought I knew itš Iām busy with a lot of things so thatās why I do not always want to learn other things like this one but I will go read and learn it I promise it
hope you keep this promise this timeā¦ you said this exact message many time as well in whatsapp groupchat, screenshots are made for you if you want to see themā¦ you saying that you have done all the research and you wont ask questions about those stupid things anymore
but i am very curious how your esk8 will end up like !
i hope you orderd good protection as well??
Engines are from 1970s motorized skateboards. Motors are from 2010s electric skateboards. I donāt suggest using an engine. It pollutes, itās loud as fuck, itās big and heavy, itās smelly, you have to buy fuel, you can burn your leg, and thereās nowhere to put it on the skateboard because itās too big.
Itās some cheap TKP trucks unbranded on custom angled wood spacers, the deck is a flat bottomed 27" cruiser
The turn isnāt bad, but it doesnāt tilt at all
Nah youāll be fine. I see people running them anywhere between 35 and 55 degree angled. Do you know if you have a 35Ā° or 45Ā° baseplate? Itās the angle between baseplate top and kingpin I believe. I see more people angling the back higher than the front by 5 or 10 degrees so you could always try only wedging the back (assuming you need motor wheel clearance)
