THIS. iโd much rather make a high end single board than an unreliable, low quality dual. iโve had both (and low quality single, high ass quality dual)
if you have the budget i obviously recommend making a high end dual, theyre just soooo much more fun, really spices up the commute. you can build one for about $1250.
What size belt should I buy. I did the measurements like the website says and it says I 305 so I bought 305 and 310 and I can not get the belt on or close and it is already tight. I have a 15T motor pulley and a 36T wheel pulley with dual idlers. I checked on here and people said 325 would be to look and possibly 320 would be too big so the next size that can be found is 310.
@Dougz
Click on the icon showing up arrow and select your images from your systemโs directory
or
Simply copy paste the link of the images after uploading them to any site like www.imgbb.com
Can sb explain me how is works? (And the difference between batt max 20 and 40?)
Batt max is f.ex 30A, while motor max may be even 80A. I do not get it.
