this will be my battery, in grey is nickel tag, orange is copper wire the green is the direction of current. and my question is do i have to thick the diameter for connection between batteries, because the voltage ground up and the currerent too.
That is the best way to run the nickel connections.
Any series connection must be 10AWG or 12AWG because it will carry the full pack current. Use super-stranded, silicone-insulated wire.
Also remember that after you make it, you will be picking it up and bashing it against a concrete wall wheels-first as hard as you can for 30 minutes. So make it able to withstand that. Well, you won’t be doing that, but you’ll be riding it which has exactly the same effect on the stuff inside
love your method for testing XD i will make a 3D print for protect the battery
I recommend 10AWG but you can get by with 12AWG
im trying to set up my vesc with ESC tool but having a noobish problem. i did my controller setup with a wizard tool and when i pull on the acceleration it always reaches top speed. for example if i pull %10 on throttle, motor ramps up slowly but steadily to %100 speed it doesnt stay at %10. i dont have this problem in BLDC tool. is there a setting that i missed in order to fix that?
you have to set the min and max for your pulsewidth also known as throttle mapping https://www.youtube.com/watch?v=TSRj1M0m8B4
that was the first thing i did but it still behaves strangely. this might be related to diy aspect of my remote. may be theres something going on with hall sensor or something.
What remote are you using
its this one: Simple 3D-printed NRF remote - Arduino controlled - ESK8 Electronics - Electric Skateboard Builders Forum | Learn How to Build your own E-board it works ok except for this problem. so far brakes work. acceleration works according to how hard i pull on the trigger but i cant keep a steady speed its really strange. edit: as you can see i keep my finger steady but it keeps accelerating to top speed.
these are the settings
You have to go into the NRF tab that is for ppm.
its designed to work with ppm and uart. i tried another remote from the same project. it behaves exactly the same way
Could someone check out my thread, I don’t know it all the electronics I picked will work together or if there is anything I’m missing. Thanks
You have 2 different motors on the build they have 2 different kv ratings
I still feel like you have to do some sort of setting with the NRF tab that is why it is there
Yeah, those were just the two I was looking at, I’ll buy two of the same verion.
And your doing a 6s build? I have the racerstar motors but I am using a 10s battery you need to do some research with the kv rating in terms of battery series.
Thanks, I’ll do some more research on finding the right size battery, any suggestions? I was thinking a 8s4p
Well if you do 8s 4p that will be alot of lipo packs because that is 32 lipo cells
Your right, any prebuild suggestions for my setup? I’ll do some more analysis on batteries.
Hello All! I have recently got a little bored of my E-Bike so i have switched into the world of E-Boards. me being a longtime longboarder and having worked with e-bikes im familiar with the concept of batteries and motors and controllers but i am looking for advice for getting a custom build. Ive gone cheap on ebikes in the past and always regret it so for this custom build i am looking for a high end build. im thinking 12s6p for battery, either a e-toxx direct drive or a powerful chain/pulley motor with gearing for both climbing and decent speed. with there being so many options for motors and battery’s i figured i would ask the professionals! thanks for your time guys i look forward to the advice… carvon evo r and the raptor 2 are very tempting but i want off road power aswell with the nice 8inch tires. cheers
