I don’t mind if I miss out on top performance if my ESC can’t handle the new motors, but would the performance with the 2 new motors and current ESC be at least equivalent to that of my current motors, until I can afford to upgrade my ESC?
The controller controls the motors and not the motors the controller.
The kV is nearly the same so also no max erpm problems.
I‘m not that expert but I would say that should work…
The controller is rated to 50a constant at 10s.
So he will also don’t give more energy out to the motors. Doesn’t matter if 55xx or 63xx
That’ll give you similar performance with the standard battery defo. I have a single drive 280 kv on 6s lipo(well I did before the kids wrecked it) and that gets up in the 22 mark. First thing i ever built.
@queue_together If you are planning on upgrading to vesc at some point then with 10s I would probably go with the lower kv option (around the 200) This will keep the max erpm under the threshold.
The thing you need to consider is how far do you want to go? That esc and battery is set up to work together from the factory and can’t be changed. If you go vesc then you will have to be careful when you set your battery max because the bms in the battery is a low amp unit and will pop if you go above 15 amp per motor.
