Prototype nuclear battery packs 10 times more power than ordinary chemical batteries
@mmaner, I’ll see your lightning powered murder board and raise you one nuclear powered battery!
So 10 times more energy but not rechargeable? No thank you. Also funny how they mix up power and energy
That would pair well with the current “murder” motif
imagine u crash into wall, those batteries fly around starts chain reaction. it will be Hiroshima all over. lol. I remember in early 2000 GM tried to make nuclear fision car. They couln’t get approval so it remained as a concept. But it was totally doable
I don’t think Nickel-63 can become supercritical
Nuclear batteries sounds great! When you run out of juice you just go to your local Mc-Donalds and ask for pink slime.
probably not but sure will be radio active tho:nauseated_face:, and it will burn quite well too
Likely future research will also explore carbon at some point:
There is an alternative radioisotope for use in nuclear batteries: Dimond converters could be made using radioactive carbon-14, which has an extremely long half-life of 5,700 years.
and work on increasing the voltage per cell (it is currently only around 1V/1uA, from memory ):
developing a diamond p-i-n structure with a controlled doping profile would boost voltage and therefore could increase the power output of the battery at least by a factor of three.
yes, it needs to be cost effective. also if we ever use this tech, we likely toss them after done. than u get problem with how or where we toss them. it well ended up paying extra fee because of this. not just manufacturing or getting a chamber to keep it safe.
