Maybe your gyro drifted and needs recalibration?
I thought Iād share my progress! I now have a working prototype. Iām using an ESP32, a VESC, and a steel frame made of 1inch square tubing. Iāve also got a mobile app which connects with bluetooth for tuning the PID loop. My end goal is to implement digital shaping, just like the actual OneWheel!
Looks Good! Can you tell us a bit more about what components you are using? And it looks like you have some kind of remote or maybe a trigger in your hand to activate the board am i right?
Thanks! So the thing in my hand is actually just an on/off switch. This current version doesnāt have any weight sensor pads, so I just needed some way to enable and disable the motor. The next version should have those pads, and will eliminate that switch.
Iāve got a blog post here with all the details. The one in this post is an older version with a different wheel, but my current version is almost exactly the same, just with the wider wheel.
I can hardly tell the difference between that and the actual OneWheel. Nice! Do you have details on how you constructed the frame?
What wheel is your new one? Do you have a link?
Hi guys Iām trying to configure my IMU. I think I did everything right but when Iām looking at the graph of angles itās seems that the axis are drifting away from there original position. My gyro is pretty much centered and my accelerometer to. Do somebody knows what to do ? Thanks !
Did you correct all the axis of the MPU? I only centered the axis that is used for balancing the board. I did try to correct and center all axis at first but that also resulted in a lot of drifting.
Fine thanks itās working better now ! Other little problem I think is that I canāt make the motor spin properly. When Iām uploading the app data on the vesc the motors makes a spin but later nothing more. Even when the imu is flat it doesnāt make the motor spin in either direction. Any ideas ? Thanks again
Thatās probably because there is no load on the motor. Set your cutoff duty cycle to 1 and the wheel should keep spinning untill you let go the footpad sensors or shut it of if you donāt have any sensors yet. Just be carefull!
Seems to work a little bit better thanks ! I think I need to have the peihub motor to do real test. So Iāll wait
Updated blog post on my version. Lots of build details for those of you who are curious!
Iām hoping for the next version to do aluminum rails, along with 3d printed bumpers and footpads, like @Remieknaapen has done. Iāll also probably be be removing the ESP32, and using the VESC balance app.
So I just started the assembly of my own onewheel, now that all my parts have finally arrived, and Iām a little confused. The vesc Iām using has 6 wires for the hall effect sensors, but the motor Iām using (phub 188) only has 5 hall effect wires? What do I do with the extra wire coming from the vesc?? Thanks!
The Vecs has a Temp. sensor input connection. The phub 188 doesnāt have a temp sensor so you donāt need to connect anything to the vesc temp. Sensor input.
For the other connections; Red wire from the phub 188 is 5v, Black wire is ground, and the other three wires are the hall signal wires and can be wired randomly to the vesc hall ports.
Hey guys I started a telegram chat room for real time talking about diy self balancing stuff.
Today I made range test on my vesc onewheel. I have about 95 kg, there is about 6*C outside (quite cold). I made 10,5 km and my 6000 mAh 12s2p sony vtc6 battery still performs but I had enough :). Voltage dropped from 50,4 to 44,6V so there was some juice left. Max speed achieved was 22 km/h. I think that in summer it will be able to reach about 18-20 km with me.
Here is small video about my board:
And some pictures:
Hi everyone,
Amazing builds. Could anyone post some details of how you are attaching the wheel axles to the side rails. Iāve never seen an actual OW so Iām unable to reverse engineer it and the pictures posted donāt quite show that detail.
Thanks.
It is a round dead axle with two flats. So itās kind of 0 shaped. Some peipei hub motors include metal plates if you order the right one, that can be bolted to aluminum rails.
