Hi
I just bought a trampa board. I got the Vesc tool app and updated the firmware and after that only one motor is running.
Can anyone help ?
Regards Stephan
Hi
Can anyone help ?
Regards Stephan
This was where you fucked up.
Also don’t believe everything that VESC Tool tells you.
YEs, I can help. When you run foc, etc, you need to run BOTH motors at once. There is a tab you need to find. It is available from the motor wizard only. If you hook up your usb to both sides, it will only run one motor. And you need to have the paired tab true, and stay that way. Took me DAYS to get that foul vesc tool to do its thing.
