Im charging with 2 Amps, so i’ll need at least 11 pins in the plug, since the bms 1. balancing cable uses the +.
I just use the BMS for charging purposes, antispark is my loop key, switch is my loop key.
I just have a totally normal, lame, 10$ BMS from China - but it works fine. I just dont want it because it is very big, and more electronics inside the board is more potential dangers of blowing something up b/c of shorting something while riding.
and yes, the BMS would be plugged in the charger, or maybe i am doing a new housing. Since a balancer for 10S lipos is fucking expensive.
