Hey all,
What kind of foam or packing material do you place inside of your enclosures to reduce materials being jostled and/or to maintain pressure against them? Cheers
Hey all,
Yoga mat
Eva foam is perfect.
Adhesive backed high density foam which does not turn into a firelighter when exposed to flame/heat
Velcro
I believe velcro works better than anything else. Either that or if the part doesn’t need to be removed then double sided 1/8th inch foam tape.
Velcro and yoga mat
Super soft neoprene and Velcro tape. the Velcro works slightly as padding
I use this, I back it with fish paper when needed, really good value
