Ok, so I managed to win a bid of 10 Toshiba Laptop batteries for £50.
Ive cracked open a few and it appears they hold Panasonic CGR18650CE Cells. Does anyone know their Amp rating or if they will be suitable for an Electric Skateboard battery. Tried doing searches, but cant seem to find anything on the Amp rating.
That’s unfortunate out the 90 cells I’ve took out. 60 of them are above 3.4v. None of the others are below 2.4v. This is going to be my first battery build so it’s a practice run. Before I buy brand new cells. Looking to test a 10s6p or 12s6p. What’s the Mac rating you think I can set in the vesc for these. Don’t really care if I fry them tbh. It’s more for learning as its my first battery build
I have these cells in my spreadsheet but I never managed to find any stats for them other than that they are 2200mAh probably.
The 2.4V cells are probably still good to use, but you have to meassure the cell capacity of ALL cells. Charge them up (to 4.1V), let them sit for at least 2-4 weeks and sort out the cells that dropped to much voltage in that time (shouldn’t be much more than 100mV). For capacity testing you cells, I recommend something like the opus bt-c3100 charger.
Since they come from Laptops, we have to assume they can do 5A tops.
To save on amperage draw of you board you would have to make it as high voltage as possible. What kind of motor or esc are you planning to use?
Test the cells discard the ten worst performers. You should be fine with 10s8p taking a few precautions. I highly recommend a quality BMS with thermal temperature probe (it’s reusable) definitely set the Vesc to draw no more than 40A
definitely make sure to capacity test every cell though, because you will have to design your battery with every parallel pack having the exact same capacity. if not you will wreck your battery in no time.
Any recommendations on the Bms. I’m new to this. Not sure what to look for. Been testing a few , charging and discharging. Omggg. This takes ages lol. What’s the max I could charge and discharge these using the charger I have. Imax v6 , I’m currently charging a single cell which was at 3.4v and its taken 1500 mah so far. Been stuck on 4.2 for a while though.
It will be a challenge getting the 80/90 cells to the board. I might make a cube type battery and strap it to the top , rather than underneath and have it lay between my feet on the board.
I won’t charge them faster than 1A. I would always discharge test at 1A. This way you get the most capcity out of them. It won’t be the real capacity you’ll get in the field since you are going to run them at their limits all the time, but for comparing the individual cells I’d go with 1A.
I stopped using the imax for capacity testing since it can only do 1 cell at a time. one of those $30 opus chargers can discharge test 4 at a time. also I think the imax is limited to 1A discharge testing while the opus can either do 4 at 1A or 2 at 2A.
As for the BMS… I don’t use one since my setup will never draw more than the battery can provide. I only use one of those $15 ones off ebay for balance charging the pack.
For you setup I would highly recommend using a BMS though… one that limits current drawn from the battery to no more than 40A (get a fuse, too). don’t know wich one is good though… I would just try one of those 10S 40A ebay ones.
Putting 90 cells are starting to become more problematic. You’re extra weight. At 45 grams per cell, the whole pack weighs 4.05 kg or 8.91 lbs. Not counting the nickel strips, solder, balance, wires, and the possibility of using the plastic cell holders.
Im not too fussed about the weight for now, this is more for learning and tinkering. Then when I get the hang of things, I will be building a better battery using BASEN 26650 4500mah, or maybe the Samsung 25R cells. Just seeing how it goes.
Quick update. After getting to grips with 18650 cells and the IMAX V6, ive started to properly test the cells. The 2 I have, I charged to 4.2v and discharged them at 1A each. Good news, First 1 measured 2084mah, and the second one is 2122mah
Considering I have to build a 9P pack, it may end up being big and bulky, but have a decent Ah. Only time will tell.
