Hello! I have a 3.5mm N5065 270kv 1800w motor, and was wondering what battery and esc would be recommended. Links would be appreciated.
Use a VESC on 10S. Make sure you limit ERPM to 60K
I would recommend one 6s lipo or two 3s lipos in series.
You can’t use a vesc or something like this: https://hobbyking.com/en_us/hobbykingr-tm-x-car-beast-series-esc-1-8-scale-120a.html
What if I went with a setup like this (a little strapped for cash atm) -https://hobbyking.com/en_us/turnigy-5000mah-6s-40c-lipo-pack.html -http://www.ebay.com/itm/single-motor-electric-longboard-skateboard-controller-ESC-Substitute-/302332747417?var=&hash=item46646f9e99:m:mGesvI1BOEcyvrLVbfKGQ8Q The esc seems a little jenky but I have suprisingly heard good things about it from eBay reviews and people on this site
For 270kv I wouldn’t even limited it runs into more issues than a 190kv or lower
Tb vesc instead of that wax and ur good
What is vesc? I hear that a lot here.
A vesc is a really good each we use for our boards, but since ur using lipos you can use an fvt esc
Ah okay. Will probably do that, but if I chose to, do you think the battery, motor and esc would work together?
Yes I do sir
