Just to start, here is my parts list so far: SK3 213kv motor (this is my ideal but might have to go 190kv if the 213kv isn’t in stock when I buy it)
2 4s1p 5000mah batteries in series for 8s 5000mah battery
Enertions VESC
Enertions 12mm drive system
XT90 anti spark loop
90m flywheel clones
Reverse kingpin 180mm trucks
For the switch, I want to use just a regular light switch and hook it up to one of the battery wires running to the VESC
Custom deck
RC car receiver and transmitter from a friend
Extra XT90, XT60, 4mm bullet connectors, and 10 AWG wire
Now for my questions
Does the parts list look good, am I missing anything? Will all the parts work well together? Can y’all point me in the direction of some good VESC configuration tutorials? Does the VESC take XT60 or XT90 connectors for the power input? Will my standard light switch idea work or will the 8s battery fry it? For connecting the batteries in series is it ok to just use the bullet connectors that come with them and just solder on an XT60 or XT90 to the remaining + and - or do I have to clip the bullet connectors of and make an XT60 or XT90 series wire harness? Is the calc.esk8.it/ calculator very accurate even If I way around 115 pounds (52 kg)? Will the Enertion wheel pulley fit my 90mm flywheel clones?
