after clicking the play button i got this:
Detection results:
Integrator limit: 105.76
BEMF Coupling: 971.72
Unknown hall error: 255
do i click apply now?
Detection results:
But you donât have hall sensors right?
theyâre sk3âs so no. unless he got them specifically made by the manufacturer with hall sensors or added his own
Make sure you have your belts disconnected while youâre running motor detection.
So since you have no idea how to do the motor detection Iâm guess you didnât do it when you put the board together. You are super lucky you didnât blow up something. Look up jacobbyâs vesc tutorials they are very in-depth
@ KeivanM Your mini remote also doesnât look like itâs installed properly. White knob should be at 2 oclock.
You donât have sensors on the sk3 motors. Make sure you set the mode to sensorless before you run motor detection and losen the belts. With this it should run through without issues
