What’s your favorite system?
- belts
- chains
- hub motors
- spur gears
0 voters
Are you running single, dual, 4wd motor drive?
- single
- dual
- 4wd
- other (leave a comment)
0 voters
If you are using belts… Which belt width are you using?
- 20mm
- 15mm
- 12mm
- 9mm
0 voters
If you are using hub motors…Which size of the hub are you using?
- 70mm
- 80mm
- 90mm
0 voters
