I am interested in building myself some anti-spark switches, but it is rather expensive to build 10. So i was wondering if anyone would be interested in buying some anti spark switches once I have built them. I would charge around $60 free shipping to CONUS. Keep in mind these would be hand soldered and I’m not trying to charge a ton, there kind of expensive to build. You would have to solder your own power wires to it, but i would include the power on push button.
I am not guaranteed to build these, I was thinking about it an thought that others may also want one.
Provide a design, or specs of said design, or walk away.
Antisparks that are poorly designed ( could be the case with yours), or without a precharge circuit, arent worth a dime because they’ll blow up in either minutes, weeks, or months.
@Gamer43 is a proper resource for antisparks. Currently he’s testing the waters of the market on the .news forum for his design.
Tldr: don’t buy antisparks from some random person who hasn’t proven their knowledge
Sorry, I should have provided more details. I got the design from github. I saw the fungineers on YT used an earlier version. I am also discussing this same thing in the electronics section.
The anti-spark switch i would be building are these from github.
This is an old design and you should really do your homework if you want to make and sell a product on here. These lack a sufficient (read as: robust/beefy) precharge circuit. Like I said above, antisparks without these will fail prematurely. There’s a reason no performance builders, or even the experienced builders building low powered boards, use Vedder based Antispark designs
I won’t say anything more, because at the end of the day it’s your choice to make and sell these, and someone else’s choice to buy them.
