Guys with 45 and 35 SR baseplates that are top mounted, do you have clearance issues anywhere?
What did you use for the clear coat? Iām in the process of sanding mine down but donāt really know what to use
I used spraymax 2k clear coat.
Any discoloration? Thinking of spraying this over some vinyl on an enclosure.
No none at all. Itās really good stuff. If you do use it make sure you have a proper respirator and cover your skin, isocyanates exposure can be legit dangerous.
donāt miss it! Itās a deal
Dual diagonal 6880ās, custom 10s5p battery with 2 output leads for DD by Psychotiller, 2 Maytech 100amp VESCās mounted front and rear for balance, SR 176mm trucks with 35Ā° front and 50Ā° rear bases. Hoyt pick remote, red and black 6 shooters.
IFā¦you get on the indigogo. its up there now for eu.
Canāt see an eu shipping option? Also whatās the difference between ācarbon deck and enclosureā vs ādeck and boxā?
it would be the ārest of worldā option for anywhere out of the usa.
box meaning the same as enclosure. I like the word more. enclosure makes me feel gross.
Just a bit at full lean.
Easy fix.
Better fix is adjustable baseplates. The are slightly taller and give you extra clearance.
I do have adjustable baseplates in mind, but Iām making my board as low, as an AT can be, will soon be able to check the fit for myself.
I had my hummie deck pretty damn low on haggy pneumatic tires. Motor clearance was the issue. The extra 1/4 made worlds of difference for motor adjustment and being able to leave my trucks lose enough to carve without them hitting the deck at full lean. I only ran one in the rear. Made it super stale.
Hereās mine. Itās a bleeping awesome deck.
Thank you all for sharing your fantastic builds. Iād love to try them. So different after all. Very good for inspiration when building.
Didnāt want to cut holes in Benās ultra nice enclosure for a vmeter. So I made this instead, to monitor charging. I can check voltages during rides on my phone.
Nice mounts, are they custom?
Thank you Yeah. I designed them in cad and cnc machined them at work. Sometimes my boss letās me use the machines.
They look super clean, do you have any close-ups?
