Hey there,
this is gonna be my first Topic on this Forum and im not used to using Forum’s but im going to try too describe everything well and have a nice conversation with you people out there !
Im really at the end of my Nerve with Trampa xD but i can laugh about it because i guess i did not make eneugh research before buying all my stuff.
I really liked E-Skating and wanted to get into it. So i watched some videos and got the impression its easy too do. Not short after i stumbeled across Trampa Boards. I too really liked them but could not affort a complete board by them and wanted my battery under the board ! So im trying to build my own. And tought Trampa is the company to go too for DIY stuff… wrong.
Trampa products really seem to have to mount to other Trampa products. And since im not from the UK its getting expensive for me only because off Tax and shipping ^^ so i need some Answers now !
So i went out and bought a Deck that i liked, which is big eneugh to fit my battery enclosure and doesnt has too much flex. Plus its more on the Freeride side than MTB(really look’s close to the ORRSOM) Picture of Deck:
Then i went with cloudwheels cause they just seem cool and have good reviews… For internals i got a 12s6p Li-Ion battery, Dual Flipsky FESC 6.6 and Motors the 63100 by Flipsky + Remote.
Now the Trampa Stuff: I bought the “new” 14FIFTIES, because Trampa support told me the 12FIFTIES would not fit a Dual 63100 Setup. And of course the 12/14FIFTIES Motormount because i loved the concept of a belt tensioner. Picture of Dual Setup:
So now i got fitment problems! I will provide Pictures!
Small problem i can fix is the motor doesnt fit in the motormount. Motor-Shaft is 10mm but bearing in Motormount only has a 8mm hole. Picture of Flipsky 63100 with Motor-Gear attached:
Picture of Motor-Shaft and Motormount with bearing installed:
I already ordered new bearing’s with a 10mm hole so no real problem there yet ^^
But next problem is when i install the Motor on the Motormount… The shaft is not really long eneugh or the mount is too thick. so that the Motor-Gear only fits over by half. I can still fasten it but do you think JB-Weld for example is necessary there? can it slide off ??
Picture of Motor installed on Motormount. Motor-Gear half on:
And i think the Hanger of the Truck just looks weird or is really ment for Carbon Boards or the ORRSOM!
Picture of Board with hangar top mounted:
Picture of Board with hangar and riser pad top mounted:
Picture of Board with hangar bottom mounted:
Picture of Board with hangar and riser pad bottom mounted:
The Riser pad just makes no sense in my eye’s or am i missing something ? XD
Worst part for me is i cant use the Cloudwheel’s one the Trucks i think
The Truck have a 12mm Axle so the Bearing’s that where with the Cloudwheel’s are 8mm.
So i ordered 12mm Bearing’s of course by Trampa because no one else sells them… but they dont fit
inside the Cloudwheels … xD
Do you guys know another option or do i need to use some Trampa wheels? because 4 Trampa Urban threads cost more than 180euro for me because of tax and stuff. Or would you suggest to buy a different Truck all together ??? But will the Motormount fit then … ?
Picture of a Cloudwheel:
Picture of a Cloudwheel with a fitting bearing:
Two Pictures of a Cloudwheel with a waay to big Trampa Bearing inside:
Will the Motormount fit any other truck ? Picture of Motormount with Messurements:
inner Diameter is 20mm
So are there any experts that can give me some good Advise ?
Thank you very much if you read trough until here and maybe this will eaven be Informative for you one Day
I wish you well have a good time Skating !!! ;D
