Programming BLDC Tool
Hey guys first build I have everything together now and now need to do the tool. I don’t really understand what info I need to put into the thing. I’m running a tb 190kv motor 12s at 8000mah 35c in series. What info should be good let me ride over the weekend.
Thanks guys
@Vermontstig The three main things you need to do to get rolling with VESC are:
  1. Configure your Battery Voltage and Amps
  2. Configure your Motor
  3. Configure your Remote
These three threads will get you up and running:
http://www.electric-skateboard.builders/t/vesc-faq-easy-to-follow-vesc-getting-started-playlist/5560
Do you have any idea how to configure the Vesc to reverse with the help of the motor itself. If yes, could you explain exactly how to.
