Hi all
I want to program my vesc but don’t want to F it up, so thought it best to ask your advice first.
Battery: 10s5p as pictured with more specs. I had a 10s3p but had to change as it did not fit (new one is deeper but shorter)
ESC is a Flipsky 75100
- Voltage:14-84V (4-20S)
- Continuous Current:100A.
- Max Current:120A.
- Firmware: latest (firmware update supported)
- ERPM:150000.
- Control Interface Ports:USB,CAN,UART.
- BEC:[email protected]
- Modes:DC, BLDC, FOC (sinusoidal)
Motor: Flipsky BLDC Belt Motor Battle Hardened 6374 190KV 3500W Brushless
I’m using the Vesc app. I went to set up the motor so far and it was asking me what size motor, small, medium or large. It had preset values for each, cookie cutter style, I assume this should be overridden and custom values entered or is it okay to use their cookie cutter mltor settings?
Also, I don’t think I can connect my bluetooth controller at the same time as the BT module/info receiver - should the controller ideally be connected for Vesc programming or does it not make a difference? Controller is Flipsky VX2.
Cheers all
