Update ~~Project: AI | Clone Vanguard | 90mm Wheel | Caliber V2 50-Degree | Duo Motor: SK3 6354 | Custom Motor Mont | Enertion VESC | 2x 4S 5000MAH 20C Update~~
Hi, Ben from Singapore, I am setup a daily transport for my work( 2.5KM distance one way).
idea setup below: Deck : Custom deck Truck : Caliber Version 2 50 Degress Wheel : 90mm wheel Pully and belt: custom 36/15 pulley and belt Motor mount : custom mounting Motor : Turnigy SK 6353 (will upgrade to dual 6354 after few months) ESC: Enertion VESC Battery : 2x 4S1P 5000MAH 20C Remote: Enerion nano-x Charger : imax B8 8S charger
I draft out my setup diagram, anyone can advise me the setup is correct?
Some part was confusing me.
- Charging 2x 4cells battery in series, how was the balance lead going to modify.
- Kep loop switch
UPDATED 21-12-2016
After nearly 3months, finally done. here is some progress photo.
Deck : Clone loaded vanguard Truck : Caliber Version 2 50 Degress Wheel : 90mm wheel Pully and belt: custom 36/12 pulley and belt Motor mount : custom mounting (from local esk8 seller) Motor : Duo Turnigy SK 6354 ESC: Duo Enertion VESC Battery : 2x 4S1P 5000MAH 20C Remote: Rc remote Charger : imax B6 (will integrate bms after new year holiday) tat is too troublesome to charge lipo. Enclosure: 3D printing carbon fiber Vesc box and Black pla battery box. Switch: Circuit breaker 120A
Waiting part to upgrade to BMS system and battery indicator.
Performance Torque 0-10: soft 10-35: strong (accident hit full throttle will fall down)
Speed:
Maximum speed i tried is 35kph. i afraid to speed up anymore as i have bike accident experience.
I think maximum speed can hit 45-50kph.
Range:
Really poor range. Around 10-12 miles. (70flat 30hill)
Overall result: Satisfy on the speed, but not the stability. Might be cause of the loose truck as i need to tight turn while i going to my workplace. Vibration make my feet so numb even using 90mm wheel. It is because the walkway was not smooth enough like road. (Singapore skateboard only can run on the pathway/walkway, not on the road) After i add in EVA form under the grip tape, will help to decrease the vibration from the board.
Wheel pulley 36t on the 90mm wheel
Taobao seller 36t:12t 5m.
Motor mounting from local esk8 part seller (customize cnc)
Ground clearance too high for me.
Lucky can catch up the last two pieces before Enertion VESC not produce this VESC anymore.
Order from local 3D printing service for the VESC carbon fiber enclosure (too small for dual VESC, faint!!!) and after printing, my friend told me carbon fiber is electric conductive. Need apply some kapton tape to prevent short circuit.
Mount on motor and adjust the enclosure location.
I need add a wooden base and fit with putty only can fit my 2 VESC.
Battery enclosure
Black tape and testing on road. Everything look good, tune up motor and battery max to get good torque and speed and brake.
Mount the battery instead of using casing to hold the battery. More secure.
Charging~~~ Add in additional battery for down light and head light.
Forget to the photo of flat cable run thought the deck to connect between battery and vesc. (clone boosted board design. (I am Casey super fans) Mount the circuit breaker and the head light on the front.
Suck spray skill on the word. But seem like B.B.
Too high? i need find way to low down the board or change to drop though deck. any advice? I might go for gullwings sidewinder 2 on front truck. Like Evolve Board
Take away the wording and plan to respray.
I need a cover for my belt and pulley. But no idea.
Switch board and light. Two light mount the truck screw.
Close up.
Two head light.
EVA form under the grip tape. 3MM.
Done.
