Really busy right now and wanted to know how to keep my vesc safe from any extra voltage and amps form my motor and batteries. I was browsing nospark connectors and came across these.
Any thoughts about how they can protect the VESC and what they should do?
so whats the deal with the spark that occurs when you pull the plug? can it ruin the VESC? I was thinking of making a dead man kill switch and was wondering if it would be a problem. Is the problem on unplugging or plugging in? or both?
the spark is actually caused by the VESC so to speak.
the spark is caused by the Caps causing a large inrush of current on connection. in fact if you connect and get a spark, then disconnect and re connect you will notice there is no spark the 2nd time.
if you charge the caps before connecting then there is no inrush (because caps are already full) and result: no spark.
and basically that’s what these devices do. they allow the caps to charge slowly through a resistor first before connecting fully.
I don’t believe that you could actually damage the VESC with (this) spark.
the connectors on the other hand… they get damaged and can erode away
edit on another note: if you DON’T get a spark when you connect that is a sign of weak Caps and caps should therefore be replaced (as I have mentioned in another thread) having sick caps CAN certainly cause damage to your ESC
there is a whole different school of thought here as well. some people refuse to use anti spark because it doesn’t continue to give a good gauge of cap health, preferring to replace their connectors every now and then rather than not knowing if their caps are dead. Castle creations actually quote “the spark is your friend”
The spark is your friend. If ever you plug your pack into your controller and you don’t see the spark, contact tech support at [email protected] or (913) 390-6939 and send the controller in for repair. Your capacitors will need to be changed. NEVER fly if you do not see the spark, especially with high voltage applications! The higher the voltage, the bigger the spark should be. Remember, the spark is your friend!!!
big. Easy to solder. No shrink wrap required. I don’t bother making a loop just use them as the main battery connection. Make sure you push them all the way together.
I also installed one on my bulk charger and I only charge through one plug. Simple. I also use a 10$ balancer/discharger and want to convert a standard 12 volt laptop charger to charge 3s packs through the balance leads. I like to only have to take one plug apart and it’s at least a big one
@NNGG or you could use an XT90 loop key and then every now any then short it to check for spark, that way you have the best of both worlds. (so long as you remember)
I gotta admit. I don’t like the spark. i have loop keys on one of my builds, and a circuit breaker on another, i have a manual charge resistor on another, and one I have nothing.
out of all I prefer the breaker.
Well I don’t really care and just want the least amount of trouble for this exact area, and If it doesn’t hurt the batteries or the VESC, then Im happpy.
I thought the spark was bad for the esc, or maybe it kills the capacitors and then the esc?
12s in series to 2 vesc in parallel. 12s to both. I wonder if anyone does esc in series.
Just Velcro. It’s temporary but those work with packs up to 3s for me. I want to pot 24 18650 li-ion cells stuck to the board in clear 70 duro polyurethane. And
Buuuuuyyyy. Mmmmmmyyyyy motoooorss! Come on guys these things rock and I’m selling them for less than anything available. I won’t screw you on rubber cost later.
And I’m charged and back out!
Really loving the board. My old board I almost never rode it was so loud and awkward. The vesc and these motors have potential.
