Yeah i know but this shoudnt be the problem because the belt should hold itself in place and not because it touches the end (the disc) of the pulley because then ur pulley shreddes itself off and u got power loss because it touches the side disc of the pulley. the belt should spin without touching anything
However ill buy a 12mm pulley and will test it and will tell how it works but i still think the problem is the wheel pulley.
Greetings
EDIT: with the 12mm pulley and after riding the pulley 50-100km the problem is solved
Perfect! I need 1 set (pulley+retainer+bolts) v2.0 for ABEC Clones with nuts in ABS+ (black) 36T 15mm.
Please tell me how much would that be (shipping to Portugal) and where to send the money.
Thanks @Idea
I will take 1 set for Kegel wheel pulley 36t in orange, please.
Is this version also with nuts to screw the bolts in, or do you screw them directly into the plastic?
