if i want to control 4 VESC with one remote,
what’s the best way to connect them.
I thought about CAN-bus between dual VESC sitting on each site
plus one receiver on each site.
I read that it should be possible to bind two receiver to one GT2B remote.
I wanted to connect each site (two VESCs) with an own own XT90S.
As I’ll need to switch on each site after each other, also the receiver will switch on after each other.
Can somebody tell me if that could be an issue?
I could also go by 2xCAN + Y-split, but I’m don’t like the idea to route the receiver cables from one site to the other site of the deck…
thats a long way to route a signal cable, if you wanna go that way id use a shielded coax cable or similar
from an rc standpoint it should be possible, ive done it with taranis and two drones at the same time, you just need to bind both of the receivers to the remote
