I have individually set identical motor settings through vesc tool and I am about to configure my remote but I’m not sure if my ESCapes are connected to each other or not.
Do I need to connect this 4 prong can bus from one escape to the other? Or does the ppm y splitter I already have connected to both take care of that?
Thats to do with the can bus being safer on the 6 variant. Split ppm is fine so long as the voltage is not duplicated across both vescs which his aren’t. Apparently all the problems with can bus on 4 are now not evident on 6 want to put that to the test? Nah fxxk that!!
