Hello,
Been in a few discussions, and after initially wanting to try hub motors for my first build, have decided to go with a single belt system instead—I’m interested in a simple setup (translated as “I’m not a rocket scientist, so the more plug and play, the better”)
BATTERY I already have a Space Cell 3 Pro (10s3p) with on/off, charging, etc. I think it has an xt60 connector for the vesc.
MOTOR / DRIVETRAIN 6374, I’ve been told. I’m leaning towards the SK3, but certainly open to other options… I’m not a huge fan of the way it looks (I know that’s not important to some & I get that.). Do all 63mm motors for esk8s have the same screw patterns, or do I need to match certain motors with certain mounts? I want Caliber II 50’s, so I’m interested in mounts for those trucks that DO NOT require mods to the truck. How about ratios? I’m pretty confused about which ratio to buy, but I’m about 185lbs. I live in Florida, so hills are pretty much non-existent. I don’t need crazy torque. Are flywheel clones a good choice, or is the consensus for the real deal—or Kegels? Oh yeah… I’m hearing 190kv as well… good?
Thanks, gang!
