I’ve currently purchased all the parts for my build except the batteries. I am borrowing some LiPos from a friend, the same friend who is going to build a lipo pack based on my needs for this board. To get a better idea I was wondering if anyone has any data they have pulled based on cruising on flatish ground between 20-30mph. Any data especially amps pulled would be helpful.
i should note, the battery amp draw in the first image is limited via vesc, i’ve set the batt max to 40a per motor since battery pack continous discharge is 80a (hg2 cells are 20a continous x 4).
if allowed, i’m sure the motor would draw even more current since they’re rated 4000+ watts, but that’s limited to what the battery pack can supply.
So the hg2 cells are 3000mah each? and 12s4p gives you 12,000mah total? so wouldn’t your constant cont amp draw be 12x20=240a? Or are the batteries a different ah rating? the 4p wouldn’t matter since its the mah total that counts
