After trying to climb a steep hill with my e-board and power just cut off, my board very often randomly breaks a very short moment. I thought it was the phase wiers so I solderd new bullet connectors between the motor and the VESC. This didnt help. I can also feel a loss in power wich I dont understand…
My setup:
VESC 4.12
Motor: 1x Alienpower 63mm 3,3KW
Battery: Alienpower 18650 pack, 12s3p
Remote/reciever: Alienpower
Enertion trucks.
I can also tell that I had no problems with the board before this.
I don’t see any settings that are that off. However, your max current ramp step in the advanced tab is 10x higher than it is by default. You may have a buggy 2.18 firmware which you may want to re-flash with a fixed one.
Your problem comes from the remote. It losses connection for a short while. Or the signal from the Potentiometer jitters. Just switch everything on and give a little throttle on the bench. Then shake the remote and squeeze it a little. If you have losses it is clear where your issue is coming from. These are the short hickups you experience.
Had the same sort of problems. Sometimes i lost power for a second going op a hill, and two times when braking, the board suddenly stops braking for a moment. Changing my remote, to a GT2B, seems to have fixed my problems (knocking on woods) so far.
