Oh shit you got him started about his glass frit
Drawing of what this pneumatic with abec core for direct drive would be helpfulā¦
shut your hole kiddo. you do not get to say this. like WTF?! are you kidding me?! You are basically saying āhe did it firstā
Oh Blitzy!
Thanks for reintroducing that
Need to test it, it seems ambitious
This is an interesting thread back from 2016
now that i saw the pictures, people shouldnāt worry about cooling the can, but rather the side of the cans
you can see on the sides, the most heated parts are the side of the cans, and i suppose the stator and the axle that would hold it.
Maybe expand the side of the cans to go around the can and touch, then add the fins in there for better heat dissipation, since DDās have limited space to do so
Maybe an enertion direct drive?
Edit: Iām just a messenger.
Is this real? O.O
Main problem for simple direct drive conversion without new truck is the width. That trucks is probably more than 35cm in width. Definetelly possible. I ma making 2 DIY DD and one itās a conversion, the other from scratch. The one from scratch is easier than the conversion because you design the parts to fit each other and not make adapters .
Is it LIQUID COOLED though?
Looks like another Chinese manufacturer are putting out DDs. Very similar to Swissboard it seems. Getting more detailsā¦ Specs donāt make a whole lot of sense https://magic-board.myshopify.com/products/electric-skateboard-direct-drive-motor-flexible-work-with-different-type-and-size-wheels-speed-be-faster-stability-durability?fbclid=IwAR2Y4G40c8J3orAWGlWYLuGsKtbtj1WQgtmw5x9Z1OfIzjsMENfhfyQ8UTM
Similar indeed.
With all of this said. Iām basically saturated below the waist from all of these direct driveās coming to market. Itās about time.
Top speed 18mph
