So, I’ve got the battery system wired up (5x2s 5300mAH 65C) and hardwired together. My BMS is set and ready for install. My Ollin VESC is also set (I haven’t set it up yet with BDLC). I wanted to post up what I’ll be doing and get the “green-light” from the experts before I start cutting and soldering.
I’m following “this” diagram, but having a hard time understanding it.
Step 1: The black wire from battery one is going to B-. Soldering on. A second black wire is being soldered from P- to the black wire of the VESC. I’ll need to create a connection through hardwired/banana connection.
Step 2: The red wire from battery 5 is being soldered directly to the VESC (also the red wire). I need to split this wire to the charge port. Which then get’s hardwired to C-.
Step 3: Hardwire the balance wires directly to the wires from the BMS. The balance wire has three colors (red, blue, and black,) the extension has black, black, and red.
I believe the BesTec page should have a basic wiring diagram as well? If I remember correctly. I have a 12S SuPower one in the mail coming and whoever answers this thread will help me out a lot too
All of the black wires in the balance connectors, are they supposed to be connected to the BMS or do they just go to a common ground?
I wouldn’t cut the XT90 off, I would suggest you make an adaptor using the opposite side of the XT90, that way you can remove the VESC from the circuit if needed.
The benefit of larger wire besides it’s ability to handle more current is that it will have less resistance than smaller wire.
Keeping your wire runs as short as possible also helps reduce resistance.
So while 12awg is usually adequate for a street board, 10awg would be better especially if your wire runs are long.
adding 10awg to the existing 12awg is not an issue and my only suggestion would be to trim the 12awg short and run the majority of the length with the heavier wire.
