Can I use a key switch with a spark switch?
Just FYI, skip the clones and I would recommend 75a original abec11 flywheels. Ideally 97mm, but 90mm minimum. They may be hard to find. You can find the 97mm 78a though, evolve sells those as well. So does chaka. I tried 97mm on crap roads and it was night and day compared to 83mm wheels, the ride is just so much better. Also looks like you’re getting an LHB deck? Make sure you get one with huge cut outs, like a witchblade variant I think he calls it. That way you can put bigger wheels on it w/o wheel bite. Be sure to have the wire channels cut out in there so it looks clean when you build it up.
Has anybody compared the 97mm clones to 97mm 78a Abecs?
Big difference?
Can’t stand green but will dye a set if it’s smoother ride
I can’t believe that awful color green
Is this the right remote?
https://www.amazon.com/FlySky-FS-GT2B-2-4GHz-3-Channel-Transmitter/dp/B00FS2U9BA
Yes
10 CHARS
I know there to small but I like the ink
http://www.tactics.com/venom/harlot-longboard-wheels/white-blue-core-82a
http://www.tactics.com/a/8hr2/9/venom-harlot-longboard-wheels-white-blue-core-82a.jpg
You may have trouble finding a wheel pulley to fit those. Most require a kegel or flywheel core.
Would it be easy or a pita to wire up to use both a 5A charger for home and a 2A charger for travel?
I’m still waiting for @longhairedboy to make me a deck. I’m about ready to quit and not build a esk8 myself!
@smurf - What are you going to use that key device for? Link to it? If that worked w/ an anti-spark switch, that would be super cool!
90mm wheels? as they are clones - do they say what duro?
Ya that was the plan use a key switch instead of a button on the anti spark switch
90’s off eBay I meant to try them out on my skateboard but it looks like the rain is here to stay
https://www.instagram.com/p/BLl0RpuD_Rr/
https://www.instagram.com/p/BLl4QTzjsG4/
Does everything have to come on the slow boat from China
https://www.amazon.com/gp/product/B018XOMG8S/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 Key is not removable in the on position so I might go with the other one instead https://www.amazon.com/gp/product/B001TR5BSE/ref=pd_sim_60_1?ie=UTF8&psc=1&refRID=PB9961969NZ9B2H01G54
