I’ve been on this forum a while, but I’m starting to seriously plan my new build. I was able to get a broken Boosted V1 Dual for a good price. It came without motors, remote and charger.
The purpose of this build is to keep it looking as close to the original Boosted Board as possible while giving it a drastic performance boost. I am planning to rebuild it with the following components:
Custom 12s2p Build to fit in Boosted Battery Case (the AA’s are only to measure size, I haven’t received cells yet)
Dual Flipsky 4.20 FSESC (pending purchase)
Dual 5055 Motors (still need, quick shipping preferred) on Boosted mount on Caliber 2s (I think)
Also, looking at DickyHo’s 50mm motor collection, should I go with the 180kV or the 270kV? Being able to go fast is always a plus but I don’t know if 270 kV is compatible with 10s or 12s?
I feel like using the Boosted enclosures will add to the overall feel of the board.
Let me know if you have any recommendations, or advice.
Thanks!
Don’t forget the BMS! If you’re going 12S, and buying from DickyHo, I would go with the 180KV motors. You could also consider the racestar 140KV units, for more torque’s.
Also boosted uses a specific belt that has much smaller ribs than most DIY guys, you’ll need to switch to a different wheel pulley or source a matching motor pulley.
Could you please provide inner Length and Width measurements for the battery casing? I’m in a very similar position to you with rebuilding a boosted, but it hasn’t quite arrived at my door yet
