Or 4x5s lipos
You could fit 4x 5s in a similar but slightly taller case. Maybe and inch taller. But yes theyāll fit. The case I have holds 2x 4s stacked on that their sides perfectly. So if you went 5s youād have to get a slightly bigger case.
At that point youāre spending about 300 on a battery thatās on a odd shape. Un less you know how to take packs apart and reshape them
Thatās definitely something to think about. Itās probably sorta water proof too I bet?
Any recommendations on a 18650 pack?
I would be willing to spend up to 300 on the right battery. It will take time but I could swing it
Yeah Iāve seen his packs. Theyāre expensive. But so are all batteries really I guess.
Go for @Boardnamics mounts. They are Rock solid and you can get the with idler bearings. Oh and they are af
Iāll give them a look thanks! Whatās the Benefit of idler pulleys? More teeth in mesh?
That would save me huge on build cost. Thanks!
Will they fit TB caliber clones?
Yes they will fit tb trucks.
So if I take say x2 5s 5000mah lipos and put them in series. That wouldnāt increase the mah correct? It would increase voltage I believe?
It would increase voltage but not capacity. For series connections you add the voltageās and the capacity reamins the same. For parallel connections you add the capacity and the voltageās stay the same. @Jgarrison34
Thanks for the confirmation. Right now Iām trying to figure out how to wire up a 10s2p pack using 5s lipos. Itās confusing lol
id go with 5x 2s lipos and with a c rating of atleast 60c. look at what @Namasaki did for his build. its actully what im building right now myself.
i actually just finished up wiring my pack. https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/8570?u=indiangummy
Okay that looks doable. The whole BMS for charging thing looks intimidating lol. Are you gonna do that or balance charge?
bms charge. i felt the same when i was in your position. use the search function and you should be able to find a lot of info. i know its intimidating but you can do it. ps im from atlanta too.
I saw the diagram @Namasaki made for his electronics setup. It made a kind of sense. I think I could do it actually. So basically after you wire the 5 2s batteries in series you then use the balance leads on each pack and plug them into the bms in order. What wires were used on the bms side of the Connection?? Then positive goes to VESC and negative goes to b- on bms? Plus there is the charging port that I donāt quite get, and a couple other things. Sorry to bombard you lol. If you donāt want to answer all these questions itās okay. Awesome! Maybe we could ride together sometime? Iām getting a meepo V2 for Christmas so Iāll have something to ride until I can get this board built. Iām in the suburbs north of the perimeter
