Title pretty much says it all. I bought an Enertion remote on here a while ago and it’s never felt right. First, the brakes come in at near 100% (locking the wheels) (with a rider) when applying the slightest amount of brake on the remote. And the weirdest part is that the remote changes polarity mid-operation (gas = brake and brake = gas). I took a video of this so you guys could better understand. The weird shit happens at 1:36, the rest of it is just cringy uncensored motor stuff.
I went without the motors this time and just watched the PPM signal on my computer. I just disconnected the signal wire from the second VESC and went up and down on the throttle for a few minutes until the signal flipped.
I am not that familiar with the Enertion remote, but I know it is similar to many others. Can you go over the exact procedure you did to pair the transmitter and remote? In what order did you turn on the board, remote or connect the transmitter? Did you need to use a jumper wire to set up the remote?
Yeah exact same thing here. If you don’t push the throttle all the way forward and then all the way brake before it connects to the receiver, it will act exactly as he says, full throttle and full brake even when barely touching it
Well, shoot. I went to rebind the receiver and managed to fuck something up. For whatever reason, the remote will now not bind to the receiver. When the receiver turns on it blinks 3-4 times slowly and then goes into the rapid blinking mode (pretty sure that’s pairing). Inserting and removing the bind key before turning on doesn’t do anything. FFFFFFFFFFFFFFFFFFFFFFFF
For reference, I was following this tutorial.
If any of you have a spare nano receiver I’d love to buy it.
I was told by enertion support that that rapid blinking is a faulty receiver. I had this problem too. They sent me a new nano-x after a lot of explaining to them what happened.
I would try to use a bind key if you have one to pair it again just in case their answer was wrong.
I had no problem with pairing my old nano-x remote to the new receiver with a bind key.
