I got a Backfire G2 and realized now after 10 months riding that I need a better range.
So my question then:
Is it possible to change the battery to something similar (physical size) without needing to replace/re-program anything else (except maybe connections)?
If I´m correct the standard battery is a 10S2P so my thought was to replace it with a 10P2S but a more powerful version.
I´ve been looking at the 10S2P at Eskating.eu
EDIT:
For other people thinking the same, battery measurements: 155 x 101 x 40 mm
Ownboard sells a 10s2p Samsung 30Q battery. Less voltage sag and 6ah capacity. The size better you check but I bet it’s compatible. Otherwise you can make it by yourself or pay someone else to do it.
You can get Meepo Sanyo 20700b 10s2p Tesla pack. It will double your range, no sag. Batteries are slightly bigger, so will fit snugger & you’ll need an adapter for the connector. Tesla 20700b cells give you 3000+ Cycles. Many other cells give 200-300 cycles.
Maybe for hub motor is enough but I think Samsung 30Q has better discharge current so better for hills climbing. Just said that because the Samsung 30q is the most used in esk8
Depends also on the ESC. Since you are not using VESC, the ESC are usually set to pull 15A at most so probably Sanyo is fine as well and you won’t notice different. Although it’s true Samsung 30W has more current available and still good capacity with a 6Ah in 2p configuration.
