The motor has too high diameter of 80mm…its too big…
IDK what is you desired top speed, but on 10s you would get 60kmph or maybe even more…you should go with lower kv motor…
what kind of direct drive? Carvon style? Hub motor?
730g is not that much…
It is really expensive, check APS motors, there are some quite similar and cheaper…
@pehra564:
@willpark16 was trying to do something similar, so I will supply you with the same threads that I sent him. You will likely end up using an SK3 motor, and for tool’s youll likely need access to a lathe, CNC machine, and 3d printer.
