I have a dual rear longboard and recently upgraded to sensored motors. these product/electric-skateboard-motor-6355-230kv-2650w/
But naturally one motor spins in the correct direction and the other does not! i know that on sensor setups there is only one correct way to connect the wires so i cant simply just swap the wires like in a sensorless brushless setup. And i attempted to program the ESC to reverse mode but it did not work. the motor (when throttle is engaged) will engage breaks.
Side note I also cant reverse even if i set the esc to forw/brake/rev mode.
Anyone know how i can reverse it?
Here is the ESC i use. product/single-motor-120a-6s-esc/
